Engine 5-speed shifting problems
Discussion in 'Powertrain' started by crb530, May 13, 2011.
    crb530 Member
    Hey guys i havent been on here in forever because i returned my corolla to stock and building a baja bug but here is my problem
    I have a 96 corolla dx 5-speed and it will not shift correctly
    It will go into 1,3,5 but as i try to shift into 2,4,R the shift housing on the trans does push the car into gear. if i reach in with my hand i can get it to click in easy. the shift cable has no breaks in it. Its the cable closest to the passinger. It almost seems like the bushing on the trans side of the cable is worn out being there is play in the bushing. I cant seem to find just the bushing for sale and i would hate to buy a whole new cable for 300 bucks when im trying to sell the car.
    does any one have any ideas for me please help
    -Chris
    crb530 Member
    no help from any one?
    its because corolla transmissions blow...replace the bushings and hope you dont need a tranny rebuild
    Ash16valve Well-Known Member
    Cape Town, South Africa
    1991 AE92 RSI 4AGTE, 2006 Run X TRD Spec
    it could be your synchros that is fckd
    Wish I had a manual so I could help.
    Nah usually when you've got a problem shifting it's due to the shift assembly on top of the transmission. I'd look more towards this being suspect due to the fact it's having a problem going into 2,4,R and those are the gears on the lower half of the shift pattern. Something's not lining up correctly in the shift assembly which would most likely point to bushings more than anything. If those are out of whack and there is too much play the selector can't engage correctly and change to the lower half of the pattern.
    We had a similar issue after one of my engine swaps... put everything together then couldn't shift gears to save my life... 1st turned into 3rd, 2nd and 3rd was non-existent, etc... it was wierd... we changed out the selector assembly on top of the transmission and reconnected the cables and it worked perfect after that... to be honest, it always amazed me the wierd ingenuity behind how that whole assembly actually shifts gears, lol.
    I was I didn't have an automatic so I could know what the hell you're talking about.
    Added: May 29, 2011 11:20 PM
    **wish
    crb530 Member
    Well guys I replaced the cable bushings with the brass one and still no change
    So if it is the shifter housing on top the trans how much will I be looking to spend for the part......anyone one know?
    Also could it be the shifter fork inside the trans?
    I need help so if anyone know please help
    Your best bet would be to go to the junkyard and take it off there. I just picked up a complete transmission for my 8thgen for 120. I wuldnt recommend buying it new since ur tyrna sell the car.
    crb530 Member
    if i pick up a trans from a junk yard how much do you guys think it will cost for someone to swap it for me?
    i mean im sure i could do it but idk what a swap takes on a corolla
    Added: Jun 20, 2011 5:43 AM
    isnt the shift assembly in side the trans? all i see are the two things that come out of the trans for the cables to hook on to.
    crb530 Member
    Well got some new news today after taking to a shop they said it was my shifter cable. kinda good news i know i dont need a new trans. now the down fall shift cables cost 300 plus about 250 to install cause i cants seem to get the old one off.
    so here is my question who has a junk yard near them and could pick me up a cable from there? i would pay for shipping and the price of the part with a little on top for who ever gets it for me
    what year/model is it? i'll take a look around.
    crb530 Member
    1996 corolla dx 5-speed
    crb530 Member
    I have still yet to find that cable at a junk yard and dont want to pay 300 bucks for a new one
    Still pokin around here... that is a rough item... you may consider just finding out if a junkyard has a 5spd corolla sitting in the yard somewhere as they may not be listing that part but it may still be in the car.
    crb530 Member
    Thanks vortex
    yeah i have been calling around there are no real yards around my house thats y i was just looking for the part so i dont have to drive an hour or two.
    but thank you for looking
    crb530 Member
    Well guys im biting the bullet and buying the cable from a dealer it will cost me like 250 but i need to sell my car i have a gst waiting for me at my friends house so forced induction here i come
