5 Speed Auto Tranny Fluid?
Discussion in 'Truck & SUV' started by YamahaTundraV8, Aug 29, 2006.
    YamahaTundraV8 New Member
    Atlanta (burbs)
    I need to replace the trans Fluid on my auto how easy is that?
    you think of doing a fluid flush or just a drain and refill?
    I'd probably replace the filter at the same time (if it has one?).. have to drop the pan to do that.
    DeebsTundra Big Tires :)
    Near VoRtEx
    Yah, CB has a good point, are you trying to flush, or just wanting to replace?
    I'm having a full Drive-Line & Transmission Service done on mine here shortly...
    You've only got 40k on that right?
    Atlanta (burbs)
    andy who are you talking to On 40k i aint even close to that yet.
    I was told every 15k the trans need's to be changed on the fluid on light duty towing is that correct ?
    Corrolla best
    I was aiming for a drain and refill and about the filter on the Tundra dont expect ill replace that as note it's a simple metal screen that needs to be cleaned when you drop the pan on the tundra. I also hate this tundra truck vs my 2000 No Dip Stick On the Trans WTF this is crazy ...
    sean2sean Member
    so cal
    i do flushes every time... when i had my turbo...
    i just remove the tranny pan... and let it drain...
    and mobil 1 syn. for trannies... every time...
