5 point racing harness review.
Discussion in 'Interior' started by GSE21tuner, Jul 1, 2008.
    Everyone who drives hard at the track needs one of these. The seat belt locking device I've seen that clips onto your seat belt doesn't even come close. I think DOT. has one. My friend had an old RJS racing harness which he just gave to me and we installed it this afternoon right over the existing piece of crap factory 3 point seatbelt. It holds you in really well. Taking hard turns hardly makes you move in your seat. I can react faster and more easily. However, I'll only using this for when I'm at the track or doing a canyon run. For normal driving, I'll still be using the stock seat belts. Pics will be up tomorrow since it's too dark outside.
    I think it's illegal...no?
    were you working on your car at 230 am?
    tsburt Active Member
    miami
    from the looks of it......YES!!
    Some racing harnesses are legal on the street provided they're not expired. They have to be replaced every once in a while to a new set with new standards. Either way, they're much safer than the standard belts. :D
    or you can just change your driving habbits and avoid crashes... thats the more economical way, especially for your wallet.
    LOL I got this harness for free. :) It helps you make turns more efficiently without your body moving around.
    DOT. Noypi ako!
    I have a CG-Lock. Works for me.:)
    hehe Here's some pics of my setup. :)
    I had the flip the head rest around since it straps me into the seat and the old position of the head rest had my head at a downward angle. LOL :D
    t0rres16 Member
    Yardley, PA
    where can i buy this?
    lol more...efficiently?
    http://www.rjsracing.com/
    This is more a heavy duty harness. It's a 3 inch wide 5 point.
    For cheaper deals, go here. However, they're for more mild use. Most likely 2 inch wide and only 4 point. You never use the 5th belt anyways. And take your pick. There are a lot of choices.
    http://www.hopupracing.com/racinggear.html
    Yeah, You don't have to shift your weight and lean into the corners leaving you with more time to concentrate on the wheel alone. For example, try taking hard turns without a seat belt on. Not recommended and purely theoretical. It's hard to steer since you're struggling to keep your ass in the seat. The harness improves upon this concept. This leaves you with full control of the wheel at all times.
    You just have to position the seat so that your wrists can rest on top of the steering wheel comfortably at a full arms length. Remember that when you install it, they must be mounted at the seat belt existing mounts. Those are the only points that are reinforced enough to hold you in. Otherwise, you'll rip the mounts right out and strip the hell out of the point, not to mention losing your restraining device. I installed this harness right over the existing belt system so that I can still use the normal belts for daily driving. That way cops can't write you up. Just say it's for the occasional track run.
    rolla02 Corollalcholic
    Delaware
    Looking good but I would have those shoulder straps mounted up on the rear deck lid. Where they are mounted now if you roll you might crush your spine.
    oh i dont track my corolla yet so i have no use for this yet
    Actually no.. Only DOT approved belts are street legal and does not expire. Racing harnesses carries either a SFI and/or FIA which carries a expiration date plus extremely strict rules about mounting and are not street legal. Only one company makes a street legal 3 and 4pt harness and it is Schroth (who also manufactures for Sparco). I had those but never used them on the streets because they're simply not too comfortable.
    The mounting method he is using is just fine and is a approved method by Sparco, Schroth, and Takata.
    i like takata!
    plu Well-Known Member
    SC
    Offtopic. Are your side airbags inside the cushion or something? Because I don't see them or how they could inflate without ripping out your chair fabric.
    you drive an auto?
    Yeah, they're inside the seats. Once they blow, I need new seats. :(
    Yes, unfortunately it's an autotragic. I had no choice in the matter since I got the car used. I might do a manual swap later in the far future.
    I don't understand why they would expire. They're not cheap to replace either.
    The webbing get loose over time. When they expire you'd either have to get the re-webbed or toss them because no sanctioning body would allow you to pass inspection (not an issue unless you actually race). That's one of the reason why most race teams opt for cheaper brands like teamtech or impact racing.
    I see. I notice that after driving with them for a while, they get a little looser. So the ones that don't expire are made to not get loose over time?
    no, the manufacturer just dont bother to get FIA or SFI approval and are not legal to use under any circumstances except car show (or autoX since they dont care). Think NRG, or the fake TRD ones on ebay. If anyone get those and die in a crash they deserve a darwin award.
    I think I'll wear my normal 3 point belt under the harness too. LOL :D Just in case it fails. The harness still holds me in pretty nicely though.
    I did that once.. I never wear my 6pt unless I have to, I couldn't even turn my body around to check my blind spot with those things on.
    Yeah, I don't wear it unless I'm canyon driving or when I will go to the track.
    dward3 Well-Known Member
    Phoenix
    Just took the car for a canyon run and the racing harness did it's magic. I didn't have to worry about sliding around in my seat. I could initiate turns faster and concentrate on the road. I'm so glad I have these. :D
    DOT. Noypi ako!
    Now let's do auto cross.
    Definitely. :)
    DOT. Noypi ako!
