4 wheel disc brack convergion
Discussion in 'Stop, Drop & Roll' started by TRDRider, Jan 4, 2007.
    TRDRider Guest
    hi i just wanted to know if there was any way of doing a 4 wheel disc brack convergion on my 95 corolla if so pls reply with all the parts needed and som instructions pls any advis is greatly apreciated
    tank u, Andrew
    94 rolla Guest
    get the new rotors, calipers, and possible brake lines if neccesary. then, look to see what else is needed with the conversion. i know you can get some tenzo-r rotors. they arent too bad and they are a pretty good price.
    dr tweak did a pretty good write up on it as well. not the same car but a little similar.
    alby13 New Member
    yeah, look up tweak. it is VERY POSSIBLE!
    although i have found even running my 93 corolla very hard in all kinds of conditions that a brake conversion for the rear would probably only benefit race track users and make maintaining it a lot easier in terms of doing the work. not sure which pads you need, which might be trickier to locate.
    cgreen38 Common sense, p
    Baton Rouge, LA
    I think Dr. Tweak has a conversion kit from a ~95ish (6th gen, I believe) Celica that can be used on Corollas.
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    Tweak's kit works for 93 - 02 Corollas.
    TRDRider Guest
    srry dr. tweak**
    midnightrolla Guest
    speaking of 4 wheel disc brakes. what brakes are campatible from what car.
    Baton Rouge, LA
    6th gen Celica GT brakes can be modified to fit.
    TRDRider Guest
    perfect thanks guys but how do i contact dr tweat??
    midnightrolla Guest
    arent those studs not 4x100
    midnightrolla Guest
    scratch that its a 5 lug, make no sence -_-.
    Baton Rouge, LA
    You use the caliper, line, brake pads, and put a 4-lug rotor on there.
    dontfucwitthe-s Guest
    I've never seen it done to a corolla before. but I'm sure it can be done.
    fuzionrolla Guest
    there are kits availble just gotta look arround i seen a few i just dont put my trust into it and they look pretty rigged up
    What if you need replacement rotors down the road. There's the possibility that he won't have them anymore.
    DOT. Noypi ako!
    MR-S are 4x100. I wonder if we could use their brakes.
    I know JDM AE111 have rear disk brake, the only problem is finding brake pads locally that would fit it.
    Baton Rouge, LA
    You have a point about using rear disks from the MR-S. Dr. Tweak would know for sure if it would work.
    Rosedale, MD
    1990 Corolla GTS rear brake pads work. That's what I use on my AE101/111 rears.
    midnightrolla Guest
    6th gen is the 4wd celica right? and also why not take the parts off a yaris? or off a honda lol? like the si? wutever works right, unless u wanna keep it all toyota
    Silver Bullet New Member
    Dr. Tweak's kit comes with 6th gen Celica GT rotors redrilled to 4 x 100. I too questioned the safety and integrity of the redrilled rotors. After about 10,000 miles of spirited and highway driving I have to say the kit is 100% safe.
    Rosedale, MD
    The stock AE101 rears.
    DOT. Noypi ako!
    Hmm.... Nice info.
    What rear disk are you using? Just the regular one or the "big disk"?
    Des Plaines, IL
    The MR-S rear brakes was already brought to the docs attention many months ago. Only problem he has is readily available parts in junk yards and such.
    legobrainboy Guest
    i use ae111 levin disc brakes all around (big discs). for the rear i use toyota corona/caldina/carina pads. i think the pads are the same as the earlier model camry's.
    DOT. Noypi ako!
