4 channel amp install
Discussion in 'Interior' started by shortys408, Jul 20, 2004.
    shortys408 Guest
    wut do most places charge for 4 channel amp install?
    superakuma Guest
    Do it yourself if you have the time.
    exspect to pay anywhere between $40-$60 for the install itself any dont let them rape you on there amp wiring kit
    like i said before if you need help ask
    shortys408 Guest
    i think i know how to do it. right now i have a head unit with 1 preout tahts being used so id get a signal from the ones goin to hte speakers to the other amp. then id get a 4 gauge amp kit and wire that to a distribution block, then take my existing 8 gauge amp kit and wire power to each amp from the block. then id probably ground them both seperate. go from one amp to anotehr with the remote wire. then wire one amp to both subs and hte 4 channel to the rear speakers then i wire speaker wire up to the front door and cut a hole in the grommet taht goes into the door panel and wire to those speakers. is that sound correct?
    superakuma Guest
    oh yea i forgot you only have one set of preout. I would say to get a new deck but I dont think you want to do that because you will be short another $200.
    I have no idea of what you just typed
    shortys408 Guest
    instead of anotehr deck ill get an adapter that goes from speakerwire to rca and use hte wire that gives the 6x9s a signal to the amp
    superakuma Guest
    Yea you can do that but your sq wont be as good.
