Engine 2zzge? multiple questions.
Discussion in 'Powertrain' started by street3887, Mar 9, 2006.
    street3887 Guest
    Concerning the 2zz swap. Would I have to custom fabricate my own mounts for the motor or are they widely manifactured as an aftermarket part? After the swap, does the motor leave any room for a turbocharger or supercharger? Where can I go to order such a motor? Also, will the 6speed transmission for the 2zzge fit the corolla? When I swap the motor I would also like to get rid of the stock 5speed.
    make your own mounts.
    the motor requires head work to reduce compression if you intend to boost it. do a LOT of research on this.
    the 6spd trans will fit. it's been done before, in a 98. what year car do you have?
    JDLangevin Guest
    You'll have to make your own, but the next time I do one I'll blueprint them so I can build them for all you guys. Yes, plenty of room for a turbo system, but it will have to be very properly built to work on the high compression engine, ideally you'd want to rebuild it with forged, low compression internals. You can usually find these on car-part.com, you can also get the JDM version from some importers. The 6-speed will work, but requries custom axles (another thing I will offer eventually, as a kit with the mounts).
    http://www.phoenixtuning.com/toyota/swaps/mantis.html
    -Doc
    Sexy, sorry just had to
    Big "S", little "s", what begins with "s"?
    ALL OF CBASS'S POSTS :mad:
    Get rid of that last "s" noob. lol
    lol, was was trying to make a lot of "S"sssssssss
    I can tell, but you're just gonna confuse cBass and he's gonna come in here with more confused and sad faces, we don't need that.
    This is true.
    yeeeesesssssssssssssssssssssssssssssssssssssss
    hehehehehe
    That's good enough for me!!
    rolla06 New Member
    Omaha, Nebraska
    2006 toyota corolla
    i have a 06 rolla. 5 spd. 60,000 miles. Completely stock. im thinkin bout boostin it. thoughts?
    What was this thread about again?
    I dont know, but im sure youll find a way to make it pokemon.
    Congratulations, you just did lol. I must remedy this.
    Added: Jan 23, 2012 11:03 PM
    So, why do you want to boost it? You are probably safe for a simple 5-7PSI bolt-on boost, more if you beef up the engine internals.
    TRD supercharger? and corolla is not that great on aftermarket "boostin" parts....just an economy car
    You think anyone listens?
    obviously not...im keeping my internals stock
    My thoughts are that you should read the first reply and do lots of research. There is not a single currently-posting member who has forced induction on their car. Not the place to ask, sorry.
    HummerH2O likes this.
    Who will be the first....
    Probably corollaGT with the way hes modding his car.
    Added: Jan 26, 2012 3:04 AM
    I'd rather do a 20v all motor swap.
    Ah, but you forgot the "currently-posting" part... which CorollaGT is not.
    Bdub215 3VZ; 2JZ
    Philadelphia Pa
    93 ES300, 92 SC300
    yep.
    Odd as this sounds, pop over to newcelica.org and pose this question. there's bound to be some good info over there. and since 9thgencorolla went dead, The 9th gen community has taken a huge hit. TN's 9th gen community is piss-poor.
    Well spoken, brother.
    amen bratha
