Engine 2zzfe
Discussion in 'Powertrain' started by rainbow_star, May 7, 2007.
    I believe you mean 2ZZ-GE right? :)
    This motor is pretty expensive, I think it's at least around US$3000
    pras211 Guest
    sorry the ge
    the new motor or a used one is 3000
    pras211 Guest
    2zzfe
    how much would a 2zzfe in good condition cost ? is it possible to get a new 2zzfe
    i want it for a swap in my 03 corolla 1zzfe motor will i have to get a transmission too or the 5 speed one will work how much can i get the 6 speed one for
    i am in india so forgive the ignorance a friend may be willing to ship one for me he s getting a huge container by ship of stuff he needs
    i wasn't aware a 2ZZFE existed - i believe you mean a 2ZZGE, from the Celica GT-S/Corolla XRS/Matrix XR?
    pras211 Guest
    so u only get used ones no chance for a new motor dont the factory sell them?
    i bought mine 3 years ago for 4000 including shipping from <a href="http://www.venus-auto.com" target="_blank">www.venus-auto.com</a> great condition for an imported engine.
    cgreen38 Common sense, p
    Baton Rouge, LA
    Not anymore.
    pras211 Guest
    where should i look for motors and how do i know if thery good
    you could always buy a car that has been in a bad accident, (rear ended preferably) and take the engine out and scrap the rest of the car. sometimes you can find them for like 2000-3000bux on ebay. or the website i referred to is usually good.
    pras211 Guest
    ok i ll browze the net and i ll be asking for one of u guys to check the thing in person for me can i count on u guys?
    jtweezy New Member
    Irving, TX
    <a href="http://www.car-part.net" target="_blank">www.car-part.net</a> has some 2zzge engines.
    shubert_ae102 New Member
    de mountains :D
    any body try to do a scion tc engine , i dont know just a thought. isnt it a d2 or something like that?
    Baton Rouge, LA
    Eh. It's OK. 160hp from a 2.4L engine isn't that great. The 2ZZ would be more powerful, has VVTL-i, and gets better mileage.
    You can use both 5 and 6 speed.
    pras211 Guest
    what modifications are necessary for the swap?
    engine mounts?? any other stuff to be moved?
    pras211 Guest
    what about the transmission will the same one work? is in the 5 speed one
    de mountains :D
    i think he meant does the tranny from the 1zz 5-speed bolt to the 2zz. i don t think the torque bands are the same between the 2 , this could bring up performance issues. definitly go with the tranny meant for the 2zz , this way you know the gearing is corredt for the torque band.
    Baton Rouge, LA
    I've asked Dr. Tweak about it, and he said the bellhousing is different. You'd have to modify it to fit. I'd just get the 6-speed that goes with the 2ZZ if I was doing the swap (wishes he was doing swap...).
    de mountains :D
    he is a tweaker. in a good way. if only he tweaked for free , or at least a 12 pack and some help.
    peter_x9 Guest
    I'm with RollaTuner110
    peter_x9 Guest
    Get a 2007 Scion TC motor if you can.
    The HP looks the same, because of the new HP rating that had been applied to all cars 07+ that takes away roughly 6-10% HP from the spec sheet. The new rating is supposedly more accurate.
    The 2.4L motor from 07's have more HP, Torque, and better engine enhancements from the 06 scion tc.
    Also, the TC is a 15.3-16.0 car depending on the car. The engine produces so much torque that even on a 2900 lbs car, you won't be able to launch it, because you will have no traction.
    Saying that, with the motor swap into a corolla (assuming it fits), with about 400-500 lbs lighter and if you get LSD and put on some slicks. You will hit 13's for sure (also assuming you have traction).
    In addition, I also feel that if you just get the 6-speed tranny and mod your engine to become a replica of a celica gt, it'd be pretty fast.
    To be honest, I've never been a fan of the 2zz-ge. K20's way better than a 2zz. The lift on a 2zz is really strong, once it kicks in, but it's not enough to do anything amazing.
    Look at the differences between a Celica GT and a GTS.
    GT:
    -5 speed tranny (long gear ratios)
    -140 hp
    -125 trq
    -Mid 15's car
    GTS:
    -6 speed tranny (short gear ratios)
    -180 hp
    -130
    -Low 15's car
    The GTS has 2 huge advantages: 40 more hp and a short gear ratio tranny
    BUT, WTF why is it only .5 seconds faster??? Any other car with those two advantages are at least 1-1.5 seconds faster.
    Conclustion, GTS motor is too expensive and weak to put that much money and time into. If you want to do a motor swap, it's cheaper and faster to go turbo, or with a motor that works.
    Thank you,
    I agree with the 2ZZ not being a very good investment. The 2.4L TC motor would be a good candidate but... its too big to fit and... its still a camry motor. I would say go with proven power. Swap in a 4AG and force feed it. Or you can just force feed the stock 1ZZFE. It would cost less than an expensive swap. But imo, I wouldn't do anything else to the car. It's a corolla. I'd save up my money and buy something else.
    Go check out newcelica.org, I think GTS run mid-low 14, not 15.
    And where did you find those numbers? car magazine?
    pras211 Guest
    i am in india a corolla is what i can afford and here its considered a luxury car
    we dont get any performance oriented cars in india we ve got to import them paying 120% dutys
    no evo no imperza no celica the corolla costs 5 times than the chepest car available
    a majority of the modded cars here are the honda citys with the 100hp stock motor
    the corolla is pretty fast
    the cars that we get here are also a lil detuned at times for the inferior fuel we get
    de mountains :D
    peter , i think your # are a little off.
    peter_x9 Guest
    <br />
    What #'s?
    peter_x9 Guest
    Shubert, I once remembered a 14's 1zzfe corolla that had some internal engine modifcation. I read up on it a long time ago when I still had a corolla. He wanted to ready it up for turbo, but had timed it to see how the modifications had effected his car.
    He had installed low compression pistons, increased his cylinder size to 2.0L, some head work, and added some electronic controllers. These things will quicken up your corolla faster than putting in a 2zz. I'm not saying install low compression pistons, but engine work will do.
    Something bothers me though, you mentioned that in your country the fuel is lower quality. That makes it extremely hard to go high compression N/A, or Turbo. If that is the case, "there's no replacement for displacement." ;)
    pras211 Guest
    we get premium fuel but its expensive so the masses use the normal fuel and cars are tuned to work on that we pay 1.19usd a liter for normal fuel and 1.42 for premium donno how to convert into gallons sorry
    pras211 Guest
    normal is 91 premium is 97 how much do u pay?
