Engine 2ZZ Cams
Discussion in 'Powertrain' started by renfield90, Jan 18, 2005.
    renfield90 New Member
    Tempe, AZ
    2ZZ Cams
    For you XRS guys...
    The company TPR that I've mentioned is making prototypes now. They're trying to do a basic Stage 1 set of cams that will still work with the stock ECU. I'm trying to find the thread that discusses all the plans in detail.
    If you got questions, you should email the owner of tpr at chris@tuningprecisionracing.com. He could probably give you the relevant threads, I'm having trouble finding them right now...
    BLADDER_MASTER Active Member
    FL
    *Moved to Engine*
