Engine 2ZZ & 1zz
Discussion in 'Powertrain' started by jamaicanballer, Sep 15, 2006.
    jamaicanballer Guest
    2ZZ & 1zz
    I was just want to find out if the 2ZZ Celica GT-S Head can fit on a 1ZZ corolla bottom end? Another thing is what would have to be done if it can work?
    jeprox Active Member
    you may want to try 9thgencorolla.com
    corolla_racer Guest
    i don;t think so man...the intake Manifold will fit.....you should go ask 9thgencorolla.com...
    SaberJ2X Lurk MOAR
    Mayawest, PR
    it will never fit....
    the intake manifold does bolt on
    lwfatt5553 Guest
    can u all help me who know the timing markking of toyota estima 2400cc vvti enjin
    lwfatt5553 Guest
    lwfatt5553 Guest
    the car is malaysia car toyota estima 2400cc vvti enjin pls help me 10q to u all
    i already 2day not sleep loh pls help me
    nes123 Guest
    the head on 2zz has a bigger bore than 1zz therefore it cant work
    It won't fit.
    They're both ZZ serise, but they don't have much in common in the block. Different bolt location, different size bore/stroke.
    The Return of D1zzy Guest
    They won't fit because nobody has tried to do the research.you could have the same bore in a 1zz by getting a big bore kit and now it will clear the valves. check to see if the dowel pins line up between the block and heads. you would really need to have a 2zz ge head and a 1zz bottom end to do this properly. good luck, mate.
    cgreen38 Common sense, p
    Baton Rouge, LA
    Baton Rouge, LA
    But if the bolt locations are different, there's no use in trying to make it fit. Plus, even if they did, you'd be spending a good bit on a big-bore kit. At that point, why wouldn't one just buy the whole 2ZZ engine? :confused:
    Vamp Gunmetal 2001 Corolla S
    Rosedale, MD
    Gunmetal Grey 2001 Corolla S
    <a href="http://www.newcelica.org/forums/showthread.php?t=219979" target="_blank">http://www.newcelica.org/forums/showthread.php?t=219979</a>
