Engine 2000(VVT-i) vs 98(1zzfe?)
Discussion in 'Powertrain' started by carbonprizm, Apr 19, 2005.
    carbonprizm Guest
    my question is I test drove a 2000 prizm today and I noticed that when I punched it, it wasnt as fast as the 98 prizm that I have now. However I know about the valve timing and all that but could that be a reason? Usually in my 98 I can take 2nd up to 45 if I wanted but in the 2000 it seemed like it was hesitating. The clutch did seem a little stiff though because when I would downshift at around 35-40mph from 4th to 3rd it always grinded no matter how far the clutch was in. My question is could the clutch be the reason why its not as responsive or is the VVT-i more restrictive for a reason???thanks for anything
    Mr_S New Member
    Kent, WA
    well im not sure about the 2000 but once in awhile my 02 grind is gears when i go back to first at around 30mph with the clutch all the way down
    Pantaloon007 Guest
    1st at 30mph? that'll grind gears every time.
    cprism: there might be somethng wrong with that 2000 you drove today.
    teevee247 Well-Known Member
    Montreal, QC
    I think there is something wrong with the 2000 Prizm... there isn't a big difference betweent he non-vvti and vvti when driving around, but the vvti does seem to pull slightly harder (comparing a 98 to a 2001 here)...
    Live2drum New Member
    ya my 01 never grinds downshifting into third so id say there may have been something wrong with the car you drove. also my car never really hesitates at all in second. i can get it all the way past 6grand with no problem
    JunGLe ChiKen New Member
    my 02 goes upto 40mph in 1st! auto!
