Engine 200 hp diy
Discussion in 'Powertrain' started by dragonitti, Jan 12, 2005.
    dragonitti Guest
    <br />
    If you spent 9k and don't have more than 96hp, then you my friend (no offense) are an idiot.
    CadetLee Guest
    I probably have at least 130 to the wheels with a 35 shot.. :p
    Phozenstone New Member
    wtf...$9k and only 96 horsepower? do you mean you gained 96 hp or summin? cuz if not it just sounds ridiculous cuz our cars are about 95hp stock to the wheels off the dyno
    Shifty SIdeways Noob
    Memphis,TN
    I think he didnt gain hp because he went lower compression for his turbo.
    ShinmaTsunami T-elos Rider
    Western NV
    Yellow vynal always works. Yellow=Perfomance
    RacingSolution New Member
    What he's done is laid the ground work to make over 300 hp in his corolla.. all he needs is a turbo now
    LoSx New Member
    hes not dumb at alll hes easily set up for over 300 hp well except his tranny that is...
    I got over 200 hp on a turbo setup...
    is it a diy??
    well I did mine?! I learned how to weld and put the fu^ker together
    was it easy: HELL NO
    was it cheap: it would have been but I used good components and decent engine management so not as cheap as it can be...
    I could prob piece one together honestly for 1500 or so I would think.. with a decent setup!
    statik New Member
    <br />
    Unless you have 7k that you want to throw into an economy car that woun't sell at a profit, then<br />
    <br />
    Nitrous...<br />
    Engine management...<br />
    End of story...<br />
    <br />
    You just need to figure out why you want a fast car. You probably think its cool. Same here. But is it practical? Are you making 60k a year? No. Do you need a reliable car? Yes. Can you still have a hobby of modifying your car without going broke or screwing it up? Yes. <br />
    <br />
    Just learn as much as you can about what people do to make an engine faster. You'll see what takes a lot of money, what is harmful to the car, what is tacky, and what you can afford and want to do. Once you define all of the areas on which you can modify, you will have a clearer picture of what is practical for you in your own way.<br />
    <br />
    All I will probably do to my corolla is;<br />
    tint windows<br />
    16&quot; rims<br />
    mesh grill<br />
    red out tail lights<br />
    change light colors on dash<br />
    get a good head unit<br />
    amp and sub<br />
    touchscreen tft /w computer in trunk<br />
    nitrous oxide<br />
    new muffler<br />
    engine management<br />
    *maybe a cat-back<br />
    <br />
    All in all it's probably under $1800. which I can afford to spend in smaller chunks throughout the year. It will be fun. I will be happy with my car. <br />
    <br />
    I know I can't afford a turbo, supercharger, or a race engine. Even if I could I would seriously think about it. The only reason I would have a supped up car would be to race it at the track. That would be an expensive hobby, if I could afford it. But I can't. I'm happy with that. I know my car will be tight even without a turbo...<br />
    <br />
    Just keep reading stuff on here, and the internet, learn about everything you can.<br />
    <br />
    You'll figure it out.
    How much whp do we have in the 125hp 00-02 rolla? Around 105-110whp?
    dragonitti Guest
    Dude...You can swap in a 3sgte for less than 9k and that includes a tranny. So, Yes, I still say he is taking the long route.
    dragonitti Guest
    I'm opting to go with a 3sgte swap, which will probably be around 8k for everything.
    On top of the 9 he has to buy a turbo too...What's that about another 2k. His approach you can throw Cost Effectiveness out in the water.
    There are some rough figures that I made up/guess/BS:
    hp/tq gain:
    Cheapo Engine management ($200-300) : +5-10hp
    Home made or aftermarket SRI/CAI ($50-200) : +1-3hp
    Muffler ($50-400) : +1-3hp
    Catback ($?:( +3-5hp
    Free up hp/tq
    Ligthen crank pulley ($100-200) : Free up 5-7hp (from Unorthodox site)
    Ligther rims (compare to what you have now)
    Smaller size rims/tire (compare to what you have now)
    Weight reduction : Every 200lbs added in your car, you lose 10hp (from a mustang site)
    Flame suit on :D
    Cape Coral, FLorida
    200 hp diy
    post a D-I-Y on the most cost offective way to get 200hp and still keep the car practical and reliable
    CivicEater Guest
    intake and exhaust should get you at least 200 HP..
    Don't forget the stickers and the "extra S and Type R" badging. Worth at least 10HP each.
    But seriously - a DIY for 200HP machine (I'm assuming 1ZZ-FE Corolla) that is practical and reliable == doesn't really go together, won't be cost effective.
    It would be cheaper to go buy brand new car with 200HP than make a 8th or 9th generation Corolla (not counting the XRS) with that much power and not break down on you.
    It also depends on what you mean by practical and reliable - if it is for one run down the track - then you can probably just run a 100HP+ shot of NOS and be done.
    Cape Coral, FLorida
    on a 00 corolla by the way
    unless intake and exhaust give u 75 horses i dont think it'd work
    CivicEater Guest
    ^^^^ like it matters what year your car is lol ^^^^^
    after reading most of your posts, i'm sure you'll also want the "cheap way" out for this question too..
    Cape Coral, FLorida
    daily driver......
    ok lets try 165 hp d-i-y practical and reliable
    CivicEater Guest
    can you build your own turbo kit?
    no?
    then you're out of luck...
    you can't DIY real HP
    93corolladx Guest
    If you want cheap power just go for nitrous.
    COROLLA1ZZ New Member
    I wish that is all it took to make 200hp
    I would have to have a turbo or s/c to make an constant 200 hp
    Cape Coral, FLorida
    hell yeah i want the cheap way, im dirt poor
    the cheapest way is to sell your car and get another one
    Cape Coral, FLorida
    even if i did it'd, cost me 2 or 3 gs to get a decent one with the money i get from the rolla....
    Memphis,TN
    Even to get around 160hp you'll have to put in over $1500, so nothings cheap in the corolla world except the owners ;)
    CivicEater Guest
    give up on the idea of having a fast car then. it's a simple as that.
    if there was some miracle trick to make 200 HP out of your car with a simple DIY, dont you think car manufacturers would already be doing that?
    "hey Eddy! when you bend the johnson rod coming out of the crankbearing, you get 200hP!"
    "shhhh! don't tell the boss, we don't want these cars to make too much power!"
    CivicEater Guest
    this statement applies to certain demographics, it has nothing to do with what car you drive. go hang out on the Evo boards, these same stupid questions are asked every day..
    man I almost have 9k in my engine right now and 3600 for my turbo. I am right now at 96hp 97tq and mine is an 01 with an auto. I lowered my compresion to 8.8:1. I have a 2.5 catback and port and polish my head.
    It will take more than 2 to 3 gs to make 200hp
    Cape Coral, FLorida
    allright fuck it....
    e_andree E
    MD
    9k? What have you done? At that rate, it will take you about 100grand for you to reach 200.
