Engine 1zzfe into a 7th gen
Discussion in 'Powertrain' started by Grinder, Nov 18, 2009.
    Grinder Well-Known Member
    does anyone know if its been done or what the issues would be getting one in
    SaberJ2X Lurk MOAR
    Mayawest, PR
    I think the only issues should be in the firewall... since the exhaust is pointing to the firewall... but other than that I don't see a mayor reason why not
    nyrican52884 Active Member
    Plymouth, MA
    Why would you want to? The 4A engines have so many more parts available, and a turbo setup would be easy.
    Rincon , Puerto Rico
    Motor mounts are way way different unless you do alot of modification nothing is impossible :)
    whydontyouchoos KFM
    Phoenix, Arizona
    if your thinking of any newer engine its 2ZZ or bust, stick with your 4A in your 7th gen so much more support for that engine
    Legit01Rolla Active Member
    ill trade you my 1zzfe for your 4a lol
    Stick with a 4a motor. Even when you do swap in a 1zz, you don't gain much.
    this
    rolla_7AFE hmong
    sacramento
    i say do it you have the money but go with a 2zz.
    Cuztomrollaz98 MAD VLAD!
    Littleton, CO.
    Go with a 2zz man, loads of parts, way more power stock and even lift hehehe.... or if you want crazy amounts of boost then get one of the Scion tC engines and swap it in there 2AZ-FE FTW when it comes to boost lol....
    SK149 Well-Known Member
    Miami
    yep i agree with almost everyone lol i don't see the point in dropping a 1zz if you can go with a 4a
    SaberJ2X Lurk MOAR
    Mayawest, PR
    boosted 7aGe!!!!
    Des Plaines, IL
    Blacktop.
    rayray1 Active Member
    Blacktop (BEAMS 3S-GE)
    its a direct fit with the exception of the left side transmission mount. you may have some issue with the sway bar clearance from the sway bar tho.
    Boosted Franken4ag
    keolaaina Well-Known Member
    If you want power, go with the 3sgte. Tremendous power potential. I think a 3sgte from a Caldina could reach 300hp with the regular bolt ons. But if you have a 4age, then that's an awesome engine that ALMOST ALL us USDM guys could dream of. Stick with that. Not the fastest engine, but balanced.
    Keep in mind block weight and the weight ratio of the car. Don't imbalance it more than it is already.
    no worries just a thought thanks for the info
