Engine 1ZZ VVT-i vs Non VVT-i Differences
Discussion in 'Powertrain' started by FriskyDingo, Dec 11, 2014.
    FriskyDingo Well-Known Member
    Canada
    2000 Corolla CE
    I've been finding small differences between the engines which no one seems to mention.
    Piston Compression Height
    • VVT-i 1.268"
    • Non VVT-i 1.256"
    I've also found that the Non VVT-i engines use the bigger valves that the 1ZZFED uses:
    Rperformance_ New Member
    But they both have the same hp? So explain that
    Canada
    2000 Corolla CE
    non-vvti has 5hp less and 3lbs less torque.Also ecu programming has a lot to do with it.
    I think the bigger valve ports being bigger has been mentioned somewhere but nice find !:thumbsup:
    Canada
    2000 Corolla CE
    It probably has but its not easy to find this info in one spot anymore by the looks of it.
    Yeah im actually trying to find something now its a but hard
    I usually google search the whole site for images or by a certain members name for reference photos
    So ive read somewhere that the corolla 1zz with vvti 5 spd can use the 2zzge injectors... So my question is can the stock rail be used ?
    Canada
    2000 Corolla CE
    Stock rail can be used and it doesnt matter if the car is an auto or manual the 1zz and 2zz both use Denso Type E injectors.1zz injectors flow around 260cc and I'm pretty sure 2zz are around 310-330cc
