Engine 1zz head swap
Discussion in 'Powertrain' started by 1.8greyghost, Oct 21, 2004.
    1.8greyghost Guest
    1zz head swap
    OK, I know you guys are going to read this and get Horribly pissed. But I just don't understand why it can't be done. The 1zz is a 2zz minus Lift, with lower comression pistons, and diffrent rev limit and fuel maping. I know there diffrent engines, but there also EXTREMELY simular. Couldn't you put a 2zz head on and run a Tec II ecu?
    teevee247 Well-Known Member
    Montreal, QC
    Although they are both in the ZZ engine family, they are actually two different blocks. It would require ALOT of machining to get them to match up properly (if at all)...
    1ZZ-FE - Bore = 79mm
    2ZZ-GE - Bore = 82mm
    That'd be one of the problems...
    blancokracker Guest
    take a look at the stroke too....
    Montreal, QC
    Yeah, stroke is quite different too, like I said, they aren't the same block...
    kickarse Guest
    well the stroke I don't think'd be a problem if the block is different... becuase it's interference anyways i believe... but to overbore to 82 is a good chance of killing it..
    polo708 New Member
    9thgencorolla.com
    MWR is coming out with some cams for the 1zz, just wait for those and you'll be happy. Way cheaper and will give a decent pick-up
    Montreal, QC
    or turbo... you can always turbo :p
