Engine 1ZZ-FE Crower Cams
Discussion in 'Powertrain' started by Phil!, Oct 30, 2013.
    Phil! Active Member
    Has anyone used them in 98-99 1ZZ-FE Corollas? Or does anyone have them in their 1ZZ-FE? I'm referring to the Cams sold from MWR, just want to know what increases in performance (torque, hp, etc) you guys got and installation process?
    Be a guinea pig!
    Phil! Active Member
    I'm down
    :ok: donation$ could really help tho
    lol jk Im trying to save up right now to put $ into the car (suspension/power)
    the fact that these parts are expensive & hard to come by doesn't help
    I wanna get as much info before I make any moves
    a cheap set was sold on ebay not too long ago...they pop up once in a while...
    Check out newcelica.org, spyderchat, or one of the other mr-s forums, they generally have higher dollar spenders. I know people have used Crower stage 1s for sure on nc.
    Yep, probably not many in a corolla but ask about the mr-s and celica
    Milky Enlarged Member
    they wont work in a non vvti head. sorry. the intake cam only works with vvti engines. one reason why i swapped to vvti.
    what would happen if say two crower exhaust cams were ran? one on the intake side and the other on the exhaust.
    God damn, that's what I just said.
    the ecu wouldnt get the cam sync signal from the magnets on the end of the intake camshaft. you can use 2 intake cams since both have the magnets, but the exhaust cams dont. so the engine might not run. i cant say for sure. i have never tried it.
    You don't say
    Best smiley I've ever made.
    :pff:
    Certainly not that one
    :milky:
    yep that one
    Boom.
    :cellphoned:
    installs cams on corolla
    :km:
    98 Corolla
    Been considering it :eek: :fyeah:
    I want to install cams on mine, but too much work.
    98 Corolla
    I have the accessibility but no funds :/
    Then maybe you can install mine :heh:
    It's really not bad on a JZ series engine.
    98 Corolla
    I'd totally do it! :D just pay for my cams hah
    You cams??? :milky: I said you could install MINE
    98 Corolla
    :deskflip: instead of paying me in cash for installing your cams, you could buy me a set for the corolla DAB
