1997 rim size
Discussion in 'Stop, Drop & Roll' started by skylin5_2, Sep 21, 2005.
    skylin5_2 Guest
    1997 rim size
    What is the largest rim size and offset that can set on a 94-97 corolla with out any modifying?
    alby13 New Member
    i imagine you can fit a 18 inch rim as i have seen someone do.
    19 is probably possible if you find a thin enough rim and tire.
    rear fender is always the problem first, then the bolts and crap under the front fender.
    i have moded front and rear fenders to fit wider tires.
