194 leds
Discussion in 'Interior' started by Takeshi, Sep 6, 2006.
    Takeshi New Member
    194 leds
    has anyone tried these? if so, which one is better. i'm thinkin of using these for my gauge cluster. i need one that has both wide angle lighting and is white. when i say white i mean white not blue/white i know from experience that some of these are blueish white.
    anyone tried these on their cluster. i'm tired of glow gauges
    metlife622@yahoo.com Banned
    i tried amber LED's before but they suck, they are bright but only in one area and the light doesnt go far enough to light the entire area, i immediately went back to regular 194 bulbs
    Tulsa, Ok
    If you used LEDs to replace the normal cluster gauges, you would only have certain lit spots...whereas, if you used the LEDs separate from the cluster gauge lights (for example: mounting them in front of your gauges projecting light onto their surface instead of shining light from behind) that would probably be the look ur going for...
    Takeshi New Member
    how do the newer corollas 2003 & up have white gauge lites?
    are those leds ?
    Kansas City, KS
    I got PIAAs on my gauge cluster and they're pretty bright.
    The thing with LED's is the viewing angle is usually very narrow.. For gauge clusters I recommend sticking to regular bulbs. PIAA is good, Polarg bi hybrid are also good, might even be cheaper.
    Takeshi New Member
    so no one with a 03 and up looked inside their gauge cluster? what kind of bulbs are in there. i know they have white bulbs. what kind?
    Does anyone know the diameter of the socket/base that attaches to 194 bulbs in the cluster of 7th gens?
    I was looking at the T1.5 and B8.3D bulbs at SuperBrightLEDs.com (check out their measurements here and scroll down a ways to check the bulbs out here too) and they they actually include a base that attaches to the bulb.
    I actually have blue LED bulbs in my cluster now and they work great. They have minor hot spots, but they're way brighter than the regular 194 bulbs the car came with. The only problem is that they have a habit of flickering on and off as they move around in the base that keeps them connected to the back of the gauge cluster. So if the base this website is selling fits the 7th gen cluster, I might just order the bulbs to avoid dealing with my own half ass craftsmanship. ;)
    cgreen38 Common sense, p
    Baton Rouge, LA
    I have blue lights in my cluster like that. They look great and they're bright as hell.
    Rolla95 Rollin' Out y0
    Deptford, New Jersey
    its not much wider that the 194 bulbs themselves, i just changed mine back to red
