17" rims back rub problem
Discussion in 'Stop, Drop & Roll' started by sins, Apr 21, 2005.
    sins New Member
    i got some 17x7 rims with 205x40x17 tires. when i put a lot of weight on the back, the rear tires rub on dips and what not.
    are there special springs i can buy to remedy this minor problem?
    Tamago New Member
    rub where? on the tread? inside? outside? what offset on those wheels?
    sins New Member
    i don't know where exactly they rub because i'm hearing it when i drive.
    The offset is in the high 40's i believe. like 47 or something.
    charlee0621 Guest
    I have an '01 and I had the same problem it is probably rubbing on the outside of the tire. I just rolled the fenders in a little bit and the problem went away.
    dragonitti Guest
    <br />
    Do you already have aftermarket springs and struts? If not, I would highly recommend getting some.
    alby13 New Member
    must be the fender lip. needs to be rolled or cut.
    this has been covered many times before. do a search.
    ghoztrider New Member
    Suburb of Philadelphia, PA
    on mine it was teh fender lips so i had mine cut, now its not as bad.... But with 4 people in my car my tread rubs off, but that will be fixed soon with newer better suspension
    yellow rolla New Member
    in boring ass charlotte, NC
    ^^^ wat they said, cut or roll that fender lip
    rolla02 Corollalcholic
    Delaware
    47 offset!!! wow I am on 43 offset on my 02. you are rubbing on the inner fenders, so yea cut or roll.
