Engine 15HP+ speed chip
Discussion in 'Powertrain' started by DOT., Jul 18, 2007.
    DOT. Noypi ako!
    Just EXACTLY 20hp for me. No more no less
    jcrwzr Member
    Simi Valley, CA
    who wants 20 or 30hp when you can have 60!?!? OR MORE!?!?! com'mon guys!
    eddy Well-Known Member
    jcrwzr Member
    Simi Valley, CA
    just bought a soldering tool. who's down for a group buy? it will probably be $15 shipped since i can get a good price at radioshack.
    i'm only making $1 if i sell these things.
    jcrwzr Member
    Simi Valley, CA
    15HP+ speed chip
    i've done the calculations and i'm getting those speed chip resistors from ebay, and daisy-chain them with a small radioshack circuit board. it if my calculations are correct it will multiply the hp.
    example
    4 chips x 15hp = 60hp!!!
    wish me luck!
    jcrwzr Member
    Simi Valley, CA
    i'm sure there's at least 60 unlockable horsepower.. that's why 4 daisy-chained speed chips is the most realistic
    I say you modify the base chip before forming a chain. That way you can exponentially increase your power gains.
    If you use a tungsten resistor, you can probably harness more power.
    shubert_ae102 New Member
    de mountains :D
    just putting in my knowledge here , but you can get the resisters from radio shack too , there really not good for your engine , it causes it to run lean , which is what "unlocks power" not good in the long run though.
    jcrwzr Member
    Simi Valley, CA
    i've taken the impedience and ohms into consideration.
    Instead of using resistors, why don't you use those vacuum tubes from back in the day. It would address your issue of impedance and ohms better. I hear they unleash electrical power at a much slower rate which would help you gain more low end power and durability. It'll also still give your electrical system the power boost that it needs to produce more horsepower.
    de mountains :D
    u r talking about the kiitle resisters that go on your ats right?
    de mountains :D
    e_andree E
    MD
    Arent those chips bullshit though?
    yes, they are.
    SleepinRolla Member
    Socal
    well you guys are partially correct, you would also need to use the proper diodes to prevent stray current from going to the ecu and frying it. Its also a good idea to to put several low pass filter to prevent and line noise from being sent to the ecu as signal. and if you really want more power you should create a differential operational amplifier circuit to boost the integrity of the modified signal via the resistors and it will also help with impedance matching. Good Luck
    15hp? darn... i'm looking for exactly 20.. 15 isn't enough.. 30 is too much..
    I'm totally down. I'll give you the money this Thursday. I'll try to rouse up the other members to join in on the buy.
    I kinda want to try a photoshoot at the new park and ride on canoga between vanowen and victory. It looks clean and lighting looks decent..i think
    DOT. Noypi ako!
    I just talked with Jon over the specs of this thing and it's intake weld friendly. It's the torque steer you really have to worry about.
    awesome, sign me up!
    I wanna see how it does for a couple of you guys. I'm a lil hesitant to try new and untested stuff on a new engine.
    ok, this whole thing is a hoax. Speed chips are bullshit and for those who believed us, the joke is on you! I don't want people to get the wrong idea and actually buy one from some fake vendor on ebay. If you want power, stick with proven bolt ons.
    thank you.
    de mountains :D
    we really need to see how the engine does in the long run , i still think after 5000 miles and you pull your plugs , they'll be ghost white.
    just an opinion.
    pras211 Guest
    i am not getting this what is it that these chips do?
    absolutely nothing. don't waste your money.
