15' x 7 fit 98' rolla?
Discussion in 'Stop, Drop & Roll' started by slvr2000fdvspec, Jul 25, 2004.
    slvr2000fdvspec Guest
    yes they fit, i got some 16x7 coming my way
    rolla_coaster New Member
    upgrading my 14' to 15'. I know 15' x 6.5 will fit, but not sure about 15' x 7.
    corolla_man_j Guest
    yea the'll fit, I've had 17 x 7.5 before
    d_samurai Guest
    yep 205 (7") width will work just fine, curious...are these like real lightweight drag or racing wheels?
    mncrolln Guest
    As long as they have the same lug nut pattern and a similar off set they will work just fine.
    thx for the input, ppl!!
    one more question....it (15' x 7) won't rub at all, right? assuming with the correct offset (38~44) and the correct lug nut pattern!!
    thx again!!
    d_samurai Guest
    yes, and the fact that it fits snug over the hub, otherwise, you may need hubcentric rings...which will prevent vibratiion at highway speeds...also, lug nuts small enough to fit into the holes..
