09 Corolla S Factory alarm or Aftermarket
Discussion in 'Interior' started by |-Goku-|, Apr 9, 2008.
Which Alarm should I install
Viper 5701 W/Remote Start $750 Installed 0 vote(s) 0.0%
Factory Alarm W/Remote Start $1000 Installed 5 vote(s) 100.0%
    I need everyones opinion on this Issue. So I would Appreciate everyones Input.
    So Since I got my 2009 Corolla S. I need an Alarm as some of you might recall from my other thread.
    I need to decide if I should get Either the Viper 5701 http://www.viper.com/Products/Product.aspx?ProductID=105
    Installed for $750...Includes remote start.
    Or If I should got with the Factory Alarm, and Remote start, for $1000 Installed
    The Price might be what some of you choose your opinion on, but what I need to decide is, Do I want an alarm that is just plug and play like the factory alarm, or do I think that I should be slicing into Wires in my brand new car. I'm wondering if the Alarm install places even have the wiring diagrams yet. I want to make sure its done very clean and I want to make sure that the Aftermarket alarm will work with the Trunk Release.
    Please let me know of your Opinions :D
    |-Goku-|
    dward3 Well-Known Member
    Phoenix
    I voted factory alarm. If you have a top notch installer then go with the viper :D
    Phan Well-Known Member
    Orange County, CA
    factory
    Found out from, the Dealer, that, when using the remote start system, When you remote start it, it will run for only 10 minutes, and you can do that twice, then you have to start the car with the key. AND when its remote started, the Cars stays locked but when you unlock it, it will turn off. Then you have to start it again, when your ready to leave.
    With the Viper, I'm pretty sure that when you remote start it, your Doors stay locked, but when you go and unlock the car, it will not shut it off. All you do is put the key in the ignition, and put the Key in the Acc, or On Position and drive away.
    The reason that I don't like the Starting twice is, doesn't that waste more gas?
    Need some more opinions :D
    go aftermarket and find a good installer. If you're not the one installing it then why would it matter if its a plug n play unit or not? Also the viper has a much longer range, why have remote start if you need to be practically standing next to the car just to start it with factory security?
    Azn_SpICe New Member
    I have the Viper, and so far, no problems......
    I have started the engine from the house and after 10 minutes or so, it turns off (i don't usually take longer than 10 minutes tho, just once in awhile)
    but yes, the car doors are locked, I would have to put the key in or just press unlock.
    I have always thought the same thing (turning on the car means burning up the gas)...that's why I try not to make too many stops
    well its gonna be a close one I'm gonna have to find a good install place if I go with viper but how do I know if they will do a quality job??
    cheeseWhizz New Member
    San Diego, CA
    dealers always over charge.. they wanted to charge me 1500 for my alarm..and 500 for some damn window tint. I vote getting a viper they are very quality alarms and remote starts and you wont get the mark up like you would from a dealer.
    Go aftermarket and get a good installer. I never found factory alarms very appealing.
    San Diego, CA
    Yeah me neither.
    zcorolla New Member
    make a friend with someone that works at best buy and have him get the alarm for you. then find a good installer. shouldn't be more thatn 500 that way. lol
