Engine 06 intake setup
Discussion in 'Powertrain' started by serpent gt, Nov 6, 2006.
    serpent gt Guest
    06 intake setup
    hi. thanks for reading my concern.
    i have a 06 corolla s and i'm going for a cai. but the intake rubber hose has a tubing into the engine and there's no vacuum lines on the air box. the vapor device or whatever it's called looks missing. is it normal on a 06?
    helps will be greatly appreciated!
    gridjockey Well-Known Member
    glendora,ca
    go for an enjin cai there is only one hose to hookup and that goes to the smog pump. all the other vacuum fittings should be capped off to avoid any cel.as of right now go with the matrix set up or wait for a corolla set up in the future.there may be a 03 corrolla intake you can use.there is no vsv sensor on the 06 http://s88.photobucket.com/albums/k...1&addtype=local
