05 Drl
Discussion in 'Exterior' started by zcorolla, Mar 26, 2007.
    zcorolla New Member
    05 Drl
    anyone know how to disable this? a step by step procedure would be really appreciated. thanks
    I'm not sure if the wiring for the 98-02 is the same for 03+. It might be the same concept but located in a different area. Vamp has the diy for disabling drl's for the 98-02. You might want to check it out.
    daniel2002p Guest
    pin 12 on the DRL module cut the wire, and ground the module side... and its done
    D
    zcorolla New Member
    would pulling out the DRL fuse do the trick?
    zcorolla New Member
    can you help me out a little more...this isnt for me...its for a friend, i need a step by step approach
    It's probably behind the glove compartment.
    daniel2002p Guest
    midnightrolla Guest
    daniel2002p Guest
    No it wont... it will set off the batt and antoher light.... <br />
    <br />
    D
    jtweezy New Member
    Irving, TX
    you dont need to ground the wire... I didnt... but yeah just cut the wire for pin 12
    mdcorolla Guest
    daniel2002p Guest
    on the 9th gen u have to... otherwise batt light comes on
    D
    jtweezy New Member
    Irving, TX
    well I guess I'm special ... I own a 05 Corolla XRS..
    mdcorolla Guest
    The RED/WHITE wire requires NO grounding.
