Engine 05 Corolla Clutch
Discussion in 'Powertrain' started by speedymach45, Apr 12, 2007.
    speedymach45 New Member
    teevee247 Well-Known Member
    Montreal, QC
    If you're just doing basic mods, and your clutch doesn't need replacement (and it shouldn't if its an '05), then save your money... its not needed.
    well i bought it used, and the synchronizer went bad. therefore i need a new clutch...
    go with the trd clutch..i think they make one for 05s
    Montreal, QC
    If the clutch is bad, then yah, try to find a deal on an aftermarket clutch... are you planning any big power adders for the future, or just basic bolt-ons? If you are just sticking with bolt-ons... just get the Stage 1 clutch... if you are planning on more serious stuff, or you plan on racing the car at a drag strip or autocross or something similar often enough, then the Stage 2 should be your choice...
    I plan on puting a small turbo this summer, along with the simple bolt ons. And going 2 the local Drag strip here
    Montreal, QC
    If you are going forced induction at all, definitely go with the Stage 2 clutch then...
    cgreen38 Common sense, p
    Baton Rouge, LA
    Go to www.jalopnik.com. They linked a video from streetfire with a guy from Fidanza. Think of it as "Clutches 1001". I've only watched 5 minutes of it, and I've learned A LOT.
    ya. that was a preaty good video btw... thanks
    any other ideas?
