03 Rolla sluggish??
Discussion in 'General Discussion' started by valve_timing, Apr 1, 2004.
    valve_timing Guest
    03 Rolla sluggish??
    Ok, I need some help. 03 Rolla 5 spd, stock all the way around.
    This morning, the engine's performance was horrendous. It's symtpoms include:
    1) Very low acceleration. I mean, maybe 1 mph increase per second.
    2) When I try to accelerate, it will do the "bucking bronco" thing and i look like some moron that doesn't know how to drive a standard.. Kinda embarresing when the car next to you is laughing his arse off.
    3) Engine idles lower, and inconsistent.
    So those are the symptoms. Now, i went looking around for anything toyota that might have the same problems.. and came up with none..
    Takin the car to the dealer tommorow to have it checked out.
    Anyone ever come across this problem??
    oxymoron Guest
    Could be a moisture problem - it was cold a rainy this morning. Did you leave it outside overnight?
    AznRolla Guest
    this may sound like a dumb reply and dont think i'm trying to be negative towards you in any way but it sounds like u were in too high of gear, such as being in 3rd instead of 4th. were u sure u were in the right gear?
    valve_timing Guest
    nooo its not that.. i know what u mean though. I mean even in 1st gear it would accelerate REALLY SLOW! I am not exaggerating when i say 1mph increase per second. I would mash my foot on the pedal in 1st gear and it would take like 20 seconds to reach 4000 rpm. THE POWER JUST ISNT THERE!!
    I hope toyota can diagnose the problem when i take it in tommorow.
    Check to see if the MAF sensor is dirty. If it gets too dirty the air doesn't mix correctly.
    moonshadow ||\\|||D)||\\||
    Jersey City, NJ
    the idle thing sounds like what happened to my car when my MAF, o2 blew and the vsv's were not comming on at all. it happened early last summer. they had to replace all those along with my fuel injectors.
    Small excerpt from the manual:
    Low engine idle speed (Poor idling)
    .....1. ISC valve circuit
    .....2. Neutral start switch circuit *
    .....3. Fuel pump control circuit
    .....4. Injector
    Rough idling (Poor idling)
    .....2. Injector
    .....3. Ignition coil (w/ Igniter) circuit
    .....4. Compression
    .....5. Fuel pump control circuit
    Hunting (Poor idling)
    .....2. ECM power source circuit
    Hesitation/Poor acceleration (Poor drivability)
    .....1. Injector
    .....2. Fuel pump control circuit
    .....4. A/T faulty *
    vanion2 Guest
    Not trying to hijack this thread but I have been looking for a service manual for the Corolla. Where did you get yours?
    edonkey
    edit: I would host it on my aim server except it's totally illegal. all my other stuff has been made or recorded by somebody.
    vanion2 Guest
    Found it. Thanks. :D
    RexPelagi VDub
    Canton, Ohio.
    I got it too now, i didnt look to closely, but its looking like some good stuff.
